주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This is an internal prerequisite that should remain unpublished.
  1. Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
    • Use a plastic opening tool to carefully pry up the flash unit at the point shown in the picture.
  2. Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  3. Remove the two 4.3 mm Phillips screws on the face of the front cover.
    • Remove the two 4.3 mm Phillips screws on the face of the front cover.
  4. Use the sharp end of a metal spudger or a razor blade to peel the sticker out of the center of the automatic/manual focus switch.
    • Use the sharp end of a metal spudger or a razor blade to peel the sticker out of the center of the automatic/manual focus switch.
  5. Remove the 6.3 mm shouldered Phillips screw from the center of the automatic/manual focus switch. Pull the automatic/manual focus switch away from the front cover.
    • Remove the 6.3 mm shouldered Phillips screw from the center of the automatic/manual focus switch.
    • Pull the automatic/manual focus switch away from the front cover.
  6. If present, remove the plastic cover from the lens mount.
    • If present, remove the plastic cover from the lens mount.
  7. Pull the front cover away from the D70.
    • Pull the front cover away from the D70.
결승점
Andrew Bookholt
552,979 평판
안내서 618개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,835
