이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace a broken rear LCD.
필요한 것
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
Use your thumbnails to push the ZIF cable lock toward the LCD.
Pull the LCD ribbon cable out of its socket.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Is there a way to test the LCD to make sure it works? Mine doesn't come on at all- no menu, no reviewing images. No backlight. Nothing. The unit takes photos fine, verified by connecting to a PC.
Some electronics tend to have a "test mode" of some sort to verify that parts work. Thought maybe this guy did as well...
