주요 콘텐츠로 건너뛰기
Nikon D70 LCD Board Replacement
필요한 것
  1. Nikon D70 LCD Board Replacement, Battery: 1 단계, 이미지 1/1
    • Use your finger tip to pull the battery release tab toward the center of the D70.
    • Open the battery door and rotate it away from the bottom cover.
  2. Nikon D70 LCD Board Replacement: 2 단계, 이미지 1/1
    • Pull the battery out of the D70.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon D70 LCD Board Replacement, Rear Cover Assembly: 3 단계, 이미지 1/1
    • Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
  4. Nikon D70 LCD Board Replacement: 4 단계, 이미지 1/1
    • Remove the two 4.8 mm Phillips screws securing the port side of the rear cover to the D70.
  5. Nikon D70 LCD Board Replacement: 5 단계, 이미지 1/2 Nikon D70 LCD Board Replacement: 5 단계, 이미지 2/2
    • Use your fingernail to flip up the ZIF locking flap on the LCD ribbon cable socket.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Pull the LCD board ribbon cable out of its socket.
  6. Nikon D70 LCD Board Replacement: 6 단계, 이미지 1/2 Nikon D70 LCD Board Replacement: 6 단계, 이미지 2/2
    • Carefully pull the sides of the rear cover away from the body of the D70.
  7. Nikon D70 LCD Board Replacement: 7 단계, 이미지 1/2 Nikon D70 LCD Board Replacement: 7 단계, 이미지 2/2
    • Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
    • At this point, the capacitor is visible and its exposed contacts are boxed in red in the second picture. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
  8. Nikon D70 LCD Board Replacement, LCD Assembly: 8 단계, 이미지 1/2 Nikon D70 LCD Board Replacement, LCD Assembly: 8 단계, 이미지 2/2
    • Use your thumbnails to push the ZIF cable lock toward the LCD.
    • Do not completely remove the ZIF cable lock. It should move about 1 mm and stop. Be sure you are pushing against the lock, not the socket.
    • Pull the LCD ribbon cable out of its socket.
  9. Nikon D70 LCD Board Replacement: 9 단계, 이미지 1/1
    • Use a pair of tweezers to pull the LCD backlight connector away from its socket.
    • It may help to wiggle the connector as you pull it out of its socket.
  10. Nikon D70 LCD Board Replacement: 10 단계, 이미지 1/2 Nikon D70 LCD Board Replacement: 10 단계, 이미지 2/2
    • Remove the two 4.8 mm Phillips screws securing the LCD bracket to the rear cover.
    • Lift the LCD bracket out of the rear cover.
  11. Nikon D70 LCD Board Replacement: 11 단계, 이미지 1/1
    • Remove the LCD assembly from the rear cover.
    • Be sure both the face of the LCD and the inner face of the clear LCD cover are perfectly clean before reassembly, as any dust or fingerprints trapped inside will be annoyingly visible when the device is turned on.
  12. Nikon D70 LCD Board Replacement, LCD Board: 12 단계, 이미지 1/1
    • Remove the three 3.1 mm Phillips screws securing the LCD board to the rear cover.
  13. Nikon D70 LCD Board Replacement: 13 단계, 이미지 1/1
    • Remove the LCD board from the rear cover.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Walter Galan
693,920 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 9,253
