이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Carefully pull the bottom cover to separate it from the body of the D70.
Remove the bottom cover from the D70.
Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
Use your fingernail to flip up the ZIF cable retaining flap on each socket.
Pull the ribbon cable straight out of its socket.
Carefully peel back the piece of tape covering the Compact Flash ribbon cable socket.
이 단계에 사용된 도구:Tweezers$4.99-
Use your fingernails to carefully pull the ZIF cable lock away from its socket.
Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
Remove the four 4.3 mm Phillips screws securing the memory compression board to the D70.
Use a pair of tweezers to pull the USB connector bracket away from the edge of the memory compression board.
Grab the memory compression board by its edges at the position shown in the first picture.
Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
다른 4명이 해당 안내서를 완성하였습니다.
