소개
If your Nikon D700 battery needs to be replaced because the it has come to the end of its life or you notice it doesn't hold a charge anymore, use this guide to remove and replace your Nikon D700 battery.
The battery provides power for your camera and is necessary for the camera to function.
Make sure your camera is powered off before removing the battery from your Nikon D700 camera.
Flip the camera over so the bottom is facing up and you'll see the battery cover.
To open the battery latch, press the latch release from right to left, and the cover should pop open.
