주요 콘텐츠로 건너뛰기
Nikon D7000 Motherboard Replacement
필요한 것
  1. Nikon D7000 Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Nikon D7000 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Gently pull the SD card cover off.
  12. Nikon D7000 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Carefully lift the back case off.
  14. Nikon D7000 Motherboard Replacement: 14 단계, 이미지 3개 중 1개 Nikon D7000 Motherboard Replacement: 14 단계, 이미지 3개 중 2개 Nikon D7000 Motherboard Replacement: 14 단계, 이미지 3개 중 3개
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 Nikon D7000 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Motherboard Replacement: 17 단계, 이미지 1개 중 1개
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Motherboard Replacement: 18 단계, 이미지 1개 중 1개
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Motherboard Replacement: 19 단계, 이미지 3개 중 1개 Nikon D7000 Motherboard Replacement: 19 단계, 이미지 3개 중 2개 Nikon D7000 Motherboard Replacement: 19 단계, 이미지 3개 중 3개
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Motherboard Replacement: 20 단계, 이미지 2개 중 1개 Nikon D7000 Motherboard Replacement: 20 단계, 이미지 2개 중 2개
  21. Nikon D7000 Motherboard Replacement: 21 단계, 이미지 1개 중 1개
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Motherboard Replacement: 22 단계, 이미지 1개 중 1개
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Motherboard Replacement: 23 단계, 이미지 1개 중 1개
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Motherboard Replacement: 24 단계, 이미지 1개 중 1개
    • Lift the motherboard off.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Jed Chen
회원 가입일: 04/01/15
1,808 평판
안내서 3개를 작성함
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G6
3 회원들
안내서 5개를 작성함
댓글 5개
perfekt. Thank you! Had to replace the board because the GPS port was brocken.
Georges Hamlet - 답글
Hi, thanks for the detailed instructions! I just replaced my main board and the new one did not boot. The battery is charged, but the LCD shows nothing when battery is in and when the power is on. Is that a problem with the replacement main board or does it need to be programmed? I expected it to power up once the power is available.
serget - 답글
Have you resolved your issue?
Bhaskar vedula -
I get CLOCK with low battery indication . I checked internal battery health and I replaced with new battery on motherboard . Now with new battery in place I see voltage 3.12v and still camera does show CLOCK symbols with low battery. Please let me know if there is hard reset makes default configuration.
Bhaskar vedula - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 20
전체 시간: 6,214
