소개
Use this guide to replace the motherboard.
Note: You'll need JIS screwdrivers for this repair. Regular Phillips screwdrivers have a cross pattern with rounded inner edges and won't fully fit the slots in the JIS screws. JIS screwdrivers instead have a straight cross pattern which makes much better contact with the screw head and is made for the high torque you will need to loosen the screws.
필요한 것
Remove the following 5 screws securing the bottom cover to the camera body:
Four 6 mm J000 screws.
One 8 mm J000 screw (under lens mount).
다른 9명이 해당 안내서를 완성하였습니다.
댓글 5개
Hi thank you.
perfekt. Thank you! Had to replace the board because the GPS port was brocken.
Hi, thanks for the detailed instructions! I just replaced my main board and the new one did not boot. The battery is charged, but the LCD shows nothing when battery is in and when the power is on. Is that a problem with the replacement main board or does it need to be programmed? I expected it to power up once the power is available.
Have you resolved your issue?
I get CLOCK with low battery indication . I checked internal battery health and I replaced with new battery on motherboard . Now with new battery in place I see voltage 3.12v and still camera does show CLOCK symbols with low battery. Please let me know if there is hard reset makes default configuration.
