주요 콘텐츠로 건너뛰기
Nikon D7000 Shutter Assembly Replacement
필요한 것
  1. Nikon D7000 Shutter Assembly Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Shutter Assembly Replacement: 2 단계, 이미지 1/1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Shutter Assembly Replacement: 3 단계, 이미지 1/2 Nikon D7000 Shutter Assembly Replacement: 3 단계, 이미지 2/2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Shutter Assembly Replacement: 4 단계, 이미지 1/1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Shutter Assembly Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Shutter Assembly Replacement: 6 단계, 이미지 1/1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Shutter Assembly Replacement: 7 단계, 이미지 1/1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Shutter Assembly Replacement: 8 단계, 이미지 1/1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Shutter Assembly Replacement: 9 단계, 이미지 1/1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Shutter Assembly Replacement: 10 단계, 이미지 1/1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Shutter Assembly Replacement: 11 단계, 이미지 1/1
    • Gently pull the SD card cover off.
  12. Nikon D7000 Shutter Assembly Replacement: 12 단계, 이미지 1/1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Shutter Assembly Replacement: 13 단계, 이미지 1/1
    • Carefully lift the back case off.
  14. Nikon D7000 Shutter Assembly Replacement: 14 단계, 이미지 1/3 Nikon D7000 Shutter Assembly Replacement: 14 단계, 이미지 2/3 Nikon D7000 Shutter Assembly Replacement: 14 단계, 이미지 3/3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Shutter Assembly Replacement: 15 단계, 이미지 1/2 Nikon D7000 Shutter Assembly Replacement: 15 단계, 이미지 2/2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Shutter Assembly Replacement: 16 단계, 이미지 1/1
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Shutter Assembly Replacement: 17 단계, 이미지 1/1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Shutter Assembly Replacement: 18 단계, 이미지 1/1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Shutter Assembly Replacement: 19 단계, 이미지 1/3 Nikon D7000 Shutter Assembly Replacement: 19 단계, 이미지 2/3 Nikon D7000 Shutter Assembly Replacement: 19 단계, 이미지 3/3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Shutter Assembly Replacement: 20 단계, 이미지 1/2 Nikon D7000 Shutter Assembly Replacement: 20 단계, 이미지 2/2
  21. Nikon D7000 Shutter Assembly Replacement: 21 단계, 이미지 1/1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Shutter Assembly Replacement: 22 단계, 이미지 1/1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Shutter Assembly Replacement: 23 단계, 이미지 1/1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Shutter Assembly Replacement: 24 단계, 이미지 1/1
    • Lift the motherboard off.
  25. Nikon D7000 Shutter Assembly Replacement, Tripod Plate: 25 단계, 이미지 1/1
    • Remove four 6 mm J000 screws securing the tripod plate.
  26. Nikon D7000 Shutter Assembly Replacement: 26 단계, 이미지 1/1
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
  27. Nikon D7000 Shutter Assembly Replacement, Image Sensor: 27 단계, 이미지 1/2 Nikon D7000 Shutter Assembly Replacement, Image Sensor: 27 단계, 이미지 2/2
    • Disconnect black and white speaker cable.
  28. Nikon D7000 Shutter Assembly Replacement: 28 단계, 이미지 1/1
    • Remove three 6 mm J000 screws securing the image sensor.
  29. Nikon D7000 Shutter Assembly Replacement: 29 단계, 이미지 1/1
    • Carefully lift the image sensor plate out of the camera.
  30. Nikon D7000 Shutter Assembly Replacement, Shutter Assembly: 30 단계, 이미지 1/1
    • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
    • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
  31. Nikon D7000 Shutter Assembly Replacement: 31 단계, 이미지 1/1
    • Remove two 5 mm J000 screws from under the flash.
  32. Nikon D7000 Shutter Assembly Replacement: 32 단계, 이미지 1/1
    • Remove two 3 mm J000 screws securing the front cover.
  33. Nikon D7000 Shutter Assembly Replacement: 33 단계, 이미지 1/2 Nikon D7000 Shutter Assembly Replacement: 33 단계, 이미지 2/2
    • Remove the front cover.
  34. Nikon D7000 Shutter Assembly Replacement: 34 단계, 이미지 1/1
    • Carefully remove the port cover.
  35. Nikon D7000 Shutter Assembly Replacement: 35 단계, 이미지 1/1
    • Deroute the microphone cable.
  36. Nikon D7000 Shutter Assembly Replacement: 36 단계, 이미지 1/1
    • Remove one 4 mm J000 screw from the front.
  37. Nikon D7000 Shutter Assembly Replacement: 37 단계, 이미지 1/1
    • Remove one 8.5 mm J000 screw from the battery compartment.
  38. Nikon D7000 Shutter Assembly Replacement: 38 단계, 이미지 1/1
    • Remove the grip carefully.
  39. Nikon D7000 Shutter Assembly Replacement: 39 단계, 이미지 1/1
    • Remove one 4 mm J000 screw securing the top case (under right strap hook).
  40. Nikon D7000 Shutter Assembly Replacement: 40 단계, 이미지 1/1
    • Remove one 4 mm J000 screw securing the top case (under left strap hook).
  41. Nikon D7000 Shutter Assembly Replacement: 41 단계, 이미지 1/1
    • Remove the sticker covering the diopter adjust screw.
  42. Nikon D7000 Shutter Assembly Replacement: 42 단계, 이미지 1/1
    • Remove one 8.0 mm J000 screw.
    • Remove the Diopeter Adjust.
  43. Nikon D7000 Shutter Assembly Replacement: 43 단계, 이미지 1/1
    • Remove the top case.
  44. Nikon D7000 Shutter Assembly Replacement: 44 단계, 이미지 1/1
    • Remove the Black, Yellow, Green cable from the top case board.
  45. Nikon D7000 Shutter Assembly Replacement: 45 단계, 이미지 1/3 Nikon D7000 Shutter Assembly Replacement: 45 단계, 이미지 2/3 Nikon D7000 Shutter Assembly Replacement: 45 단계, 이미지 3/3
    • Remove two 6.5 mm J000 screws securing the viewfinder.
    • Remove the viewfinder cover.
  46. Nikon D7000 Shutter Assembly Replacement: 46 단계, 이미지 1/1
    • Remove one 3 mm J000 screw from the bottom left side of the camera.
  47. Nikon D7000 Shutter Assembly Replacement: 47 단계, 이미지 1/1
    • Remove two 6 mm J000 screws from the left of the shutter.
  48. Nikon D7000 Shutter Assembly Replacement: 48 단계, 이미지 1/1
    • Remove two 6.5 mm J000 screws from beneath the lens mount.
  49. Nikon D7000 Shutter Assembly Replacement: 49 단계, 이미지 1/1
    • Remove two screws from just below and to the sides of the viewfinder.
  50. Nikon D7000 Shutter Assembly Replacement: 50 단계, 이미지 1/1
    • Remove one 5 mm J000 screw from the top right of the camera.
  51. Nikon D7000 Shutter Assembly Replacement: 51 단계, 이미지 1/1
    • Carefully peel back ribbon cable on the bottom left of camera.
  52. Nikon D7000 Shutter Assembly Replacement: 52 단계, 이미지 1/2 Nikon D7000 Shutter Assembly Replacement: 52 단계, 이미지 2/2
    • Remove the left front ribbon cable from top right of circuit board.
  53. Nikon D7000 Shutter Assembly Replacement: 53 단계, 이미지 1/1
    • Remove all three wire connectors.
  54. Nikon D7000 Shutter Assembly Replacement: 54 단계, 이미지 1/1
    • Separate the shutter assembly from the camera body.
결론
다른 34명이 해당 안내서를 완성하였습니다.
Steven Castaneda
회원 가입일: 04/02/15
676 평판
안내서 1개 작성함
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G6
3 회원들
안내서 5개 작성하였습니다
댓글 10개
Use a #00 Philips, not a #0, or you'll strip the screws. Also, there are two or three screws connecting the shutter assembly to the camera body, and its contacts are soldered on. So you need a soldering iron for the last step.
Michael Duncan - 답글
im gonna be trying this soon , how long did it take and how difficult is it ,,,
Dean Wilkinson - 답글
Guide not completed. Last step only shows removal of mirror box. Shutter assembly replacement not
Ziyang - 답글
Regardless of possibly a few missing steps, this is a great lesson of how to deal with shutter replacement on my own. Hats off !!
Mateusz Witek - 답글
How to reassemble diopter adjustment?
Jerome - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 26
30일 전: 75
전체 시간: 19,016
