주요 콘텐츠로 건너뛰기
Nikon D7000 Tripod Plate Replacement
필요한 것
  1. Nikon D7000 Tripod Plate Replacement, Motherboard: 1 단계, 이미지 1/1
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
  2. Nikon D7000 Tripod Plate Replacement: 2 단계, 이미지 1/1
    • Remove three 6 mm J000 screws from under the battery cover.
  3. Nikon D7000 Tripod Plate Replacement: 3 단계, 이미지 1/2 Nikon D7000 Tripod Plate Replacement: 3 단계, 이미지 2/2
    • Gently pull the bottom cover off of the camera body.
  4. Nikon D7000 Tripod Plate Replacement: 4 단계, 이미지 1/1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
  5. Nikon D7000 Tripod Plate Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Peel the rear rubber piece off with tweezers.
  6. Nikon D7000 Tripod Plate Replacement: 6 단계, 이미지 1/1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
  7. Nikon D7000 Tripod Plate Replacement: 7 단계, 이미지 1/1
    • Pull the eyepiece cover up to remove it.
  8. Nikon D7000 Tripod Plate Replacement: 8 단계, 이미지 1/1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
  9. Nikon D7000 Tripod Plate Replacement: 9 단계, 이미지 1/1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
  10. Nikon D7000 Tripod Plate Replacement: 10 단계, 이미지 1/1
    • Remove four 6 mm J000 screws that secure the SD card cover.
  11. Nikon D7000 Tripod Plate Replacement: 11 단계, 이미지 1/1
    • Gently pull the SD card cover off.
  12. Nikon D7000 Tripod Plate Replacement: 12 단계, 이미지 1/1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
  13. Nikon D7000 Tripod Plate Replacement: 13 단계, 이미지 1/1
    • Carefully lift the back case off.
  14. Nikon D7000 Tripod Plate Replacement: 14 단계, 이미지 1/3 Nikon D7000 Tripod Plate Replacement: 14 단계, 이미지 2/3 Nikon D7000 Tripod Plate Replacement: 14 단계, 이미지 3/3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
  15. Nikon D7000 Tripod Plate Replacement: 15 단계, 이미지 1/2 Nikon D7000 Tripod Plate Replacement: 15 단계, 이미지 2/2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
  16. Nikon D7000 Tripod Plate Replacement: 16 단계, 이미지 1/1
    • Gently pry and lift the left motherboard shield off.
  17. Nikon D7000 Tripod Plate Replacement: 17 단계, 이미지 1/1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
  18. Nikon D7000 Tripod Plate Replacement: 18 단계, 이미지 1/1
    • Gently lift the right motherboard shield off with the tip of a spudger.
  19. Nikon D7000 Tripod Plate Replacement: 19 단계, 이미지 1/3 Nikon D7000 Tripod Plate Replacement: 19 단계, 이미지 2/3 Nikon D7000 Tripod Plate Replacement: 19 단계, 이미지 3/3
    • Disconnect remaining ribbon cables.
  20. Nikon D7000 Tripod Plate Replacement: 20 단계, 이미지 1/2 Nikon D7000 Tripod Plate Replacement: 20 단계, 이미지 2/2
  21. Nikon D7000 Tripod Plate Replacement: 21 단계, 이미지 1/1
    • Carefully disconnect the red connector with tweezers.
  22. Nikon D7000 Tripod Plate Replacement: 22 단계, 이미지 1/1
    • Remove four 3.5 mm J000 screws securing the motherboard.
  23. Nikon D7000 Tripod Plate Replacement: 23 단계, 이미지 1/1
    • Gently pull the port side cover away from the motherboard.
  24. Nikon D7000 Tripod Plate Replacement: 24 단계, 이미지 1/1
    • Lift the motherboard off.
  25. Nikon D7000 Tripod Plate Replacement, Tripod Plate: 25 단계, 이미지 1/1
    • Remove four 6 mm J000 screws securing the tripod plate.
  26. Nikon D7000 Tripod Plate Replacement: 26 단계, 이미지 1/1
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jed Chen
회원 가입일: 04/01/15
1,796 평판
안내서 3개 작성하였습니다
Cal Poly, Team 24-6, Lancaster Spring 2015 Cal Poly, Team 24-6, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 2,340
