주요 콘텐츠로 건너뛰기
Nikon D7100 Headphone/Microphone Replacement
필요한 것
  1. Nikon D7100 Headphone/Microphone Replacement, LCD Screen: 1 단계, 이미지 1/1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
  2. Nikon D7100 Headphone/Microphone Replacement: 2 단계, 이미지 1/1
    • Remove the 3 screws under the battery flap and remove the bottom cover.
  3. Nikon D7100 Headphone/Microphone Replacement: 3 단계, 이미지 1/1
    • Remove the 2 screws inside the camera on the back corners.
  4. Nikon D7100 Headphone/Microphone Replacement: 4 단계, 이미지 1/1
    • Open the HDMI flap and remove the 2 screws.
  5. Nikon D7100 Headphone/Microphone Replacement: 5 단계, 이미지 1/1
    • Remove the screw next to the camera strap loop.
  6. Nikon D7100 Headphone/Microphone Replacement: 6 단계, 이미지 1/1
    • Remove the 2 screws on each side of the view finder.
  7. Nikon D7100 Headphone/Microphone Replacement: 7 단계, 이미지 1/1
    • Remove the 2 screws above and below the SD card flap.
  8. Nikon D7100 Headphone/Microphone Replacement: 8 단계, 이미지 1/1
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
  9. Nikon D7100 Headphone/Microphone Replacement: 9 단계, 이미지 1/2 Nikon D7100 Headphone/Microphone Replacement: 9 단계, 이미지 2/2
    • Remove the Diopter adjustment control sticker and remove the screw under it.
  10. Nikon D7100 Headphone/Microphone Replacement: 10 단계, 이미지 1/1
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
  11. Nikon D7100 Headphone/Microphone Replacement: 11 단계, 이미지 1/1
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
  12. Nikon D7100 Headphone/Microphone Replacement: 12 단계, 이미지 1/2 Nikon D7100 Headphone/Microphone Replacement: 12 단계, 이미지 2/2
    • Unscrew all 16 screws around the back plate of the camera.
  13. Nikon D7100 Headphone/Microphone Replacement: 13 단계, 이미지 1/1
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
  14. Nikon D7100 Headphone/Microphone Replacement, Motherboard: 14 단계, 이미지 1/1
    • Undo the 5 ribbon cable connectors by flipping the latches up with a plastic spudger.
  15. Nikon D7100 Headphone/Microphone Replacement: 15 단계, 이미지 1/1
    • Remove the black 4 pin connector by pulling it out of the connector.
  16. Nikon D7100 Headphone/Microphone Replacement: 16 단계, 이미지 1/1
    • Remove the 7 screws holding the motherboard in place.
  17. Nikon D7100 Headphone/Microphone Replacement: 17 단계, 이미지 1/1
    • This is what you should see after removing the motherboard.
  18. Nikon D7100 Headphone/Microphone Replacement, Headphone and Microphone Module: 18 단계, 이미지 1/1
    • After following the guide to remove the back LCD screen from the motherboard, remove the 2 marked screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Wesley Eveld
회원 가입일: 02/20/18
732 평판
안내서 4개 작성하였습니다
USF Tampa, Team S11-G6, Cheng Spring 2018 USF Tampa, Team S11-G6, Cheng Spring 2018 회원
USFT-CHENG-S18S11G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 1,071
