주요 콘텐츠로 건너뛰기
Nikon D7100 Motherboard Replacement
필요한 것
  1. Nikon D7100 Motherboard Replacement, LCD Screen: 1 단계, 이미지 1/1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
  2. Nikon D7100 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the 3 screws under the battery flap and remove the bottom cover.
  3. Nikon D7100 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the 2 screws inside the camera on the back corners.
  4. Nikon D7100 Motherboard Replacement: 4 단계, 이미지 1/1
    • Open the HDMI flap and remove the 2 screws.
  5. Nikon D7100 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the screw next to the camera strap loop.
  6. Nikon D7100 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the 2 screws on each side of the view finder.
  7. Nikon D7100 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the 2 screws above and below the SD card flap.
  8. Nikon D7100 Motherboard Replacement: 8 단계, 이미지 1/1
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
  9. Nikon D7100 Motherboard Replacement: 9 단계, 이미지 1/2 Nikon D7100 Motherboard Replacement: 9 단계, 이미지 2/2
    • Remove the Diopter adjustment control sticker and remove the screw under it.
  10. Nikon D7100 Motherboard Replacement: 10 단계, 이미지 1/1
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
  11. Nikon D7100 Motherboard Replacement: 11 단계, 이미지 1/1
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
  12. Nikon D7100 Motherboard Replacement: 12 단계, 이미지 1/2 Nikon D7100 Motherboard Replacement: 12 단계, 이미지 2/2
    • Unscrew all 16 screws around the back plate of the camera.
  13. Nikon D7100 Motherboard Replacement: 13 단계, 이미지 1/1
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
  14. Nikon D7100 Motherboard Replacement, Motherboard: 14 단계, 이미지 1/1
    • Undo the 5 ribbon cable connectors by flipping the latches up with a plastic spudger.
  15. Nikon D7100 Motherboard Replacement: 15 단계, 이미지 1/1
    • Remove the black 4 pin connector by pulling it out of the connector.
  16. Nikon D7100 Motherboard Replacement: 16 단계, 이미지 1/1
    • Remove the 7 screws holding the motherboard in place.
  17. Nikon D7100 Motherboard Replacement: 17 단계, 이미지 1/1
    • This is what you should see after removing the motherboard.
결론
Remember to replace your broken components. Then follow the instructions in reverse order to reassemble your device.
다른 6명이 해당 안내서를 완성하였습니다.
Alexander DiMartino
회원 가입일: 03/06/18
166 평판
안내서 1개 작성함
USF Tampa, Team S11-G6, Cheng Spring 2018 USF Tampa, Team S11-G6, Cheng Spring 2018 회원
USFT-CHENG-S18S11G6
4 회원들
안내서 6개 작성하였습니다
댓글 2개
Great guide. I utilized Alexander's instructions successfully in order to remove the LCD screen on the back as well as removing the motherboard in order to swab out remnants of a soda that my Nikon D7200 drank when the soda burst in my camera bag, it was a hot day that day. The instructions worked out beautifully and the only things I would recommend is to take care with counting the amounts of screws removed for each step. Step 6 has 2 screws to be removed and Step 7 has 4 screws to be removed. Also make a note of the different sizes of screws, shorter or longer, and their respective locations so that the reassembly is done correctly. The operation on my camera was a success as it allowed me to find areas where soda had dried and impeded some of the copper grounding connections inside of the camera body causing an "Err" message and rendering my camera inoperable. I thank Alexander and the other contributors for putting this out into the world, you saved me some serious cash side stepping camera repair costs.
Drew Creates - 답글
Great guide indeed!
After installing the new motherboard, are there any software settings that "authorized Nikon service only do" or can everything work without it?
Milos Cirkovic - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 52
전체 시간: 3,927
