주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Nikon D800 Top LCD Cover Glass Replacement
필요한 것
  1. Nikon D800 Top LCD Cover Glass Replacement, iOpener Heating: 1 단계, 이미지 1/2 Nikon D800 Top LCD Cover Glass Replacement, iOpener Heating: 1 단계, 이미지 2/2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. Nikon D800 Top LCD Cover Glass Replacement: 2 단계, 이미지 1/1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. Nikon D800 Top LCD Cover Glass Replacement: 3 단계, 이미지 1/1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. Nikon D800 Top LCD Cover Glass Replacement, Alternate iOpener heating method: 4 단계, 이미지 1/2 Nikon D800 Top LCD Cover Glass Replacement, Alternate iOpener heating method: 4 단계, 이미지 2/2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. Nikon D800 Top LCD Cover Glass Replacement, Top LCD Glass: 5 단계, 이미지 1/1
    • Lay a warm iOpener over the LCD glass to soften the adhesive holding it in place.
    • The following steps involve prying the glass up and out of the camera. If at any time you encounter too much resistance, reheat and reapply the iOpener to loosen the adhesive.
  6. Nikon D800 Top LCD Cover Glass Replacement: 6 단계, 이미지 1/2 Nikon D800 Top LCD Cover Glass Replacement: 6 단계, 이미지 2/2
    • Before beginning, lay a piece of packing tape over the broken glass to hold it together during the removal procedure.
    • Insert a curved razor blade between the LCD glass cover and the body of D800.
    • The blade is sharp, and can damage the LCD. When completing this repair, do not insert the knife more than 3 mm into the LCD window to avoid damaging the display.
  7. Nikon D800 Top LCD Cover Glass Replacement: 7 단계, 이미지 1/3 Nikon D800 Top LCD Cover Glass Replacement: 7 단계, 이미지 2/3 Nikon D800 Top LCD Cover Glass Replacement: 7 단계, 이미지 3/3
    • Slide the curved razor blade along the front edge of the LCD.
  8. Nikon D800 Top LCD Cover Glass Replacement: 8 단계, 이미지 1/3 Nikon D800 Top LCD Cover Glass Replacement: 8 단계, 이미지 2/3 Nikon D800 Top LCD Cover Glass Replacement: 8 단계, 이미지 3/3
    • Bring the blade around the corner of the LCD closest to the shutter button.
  9. Nikon D800 Top LCD Cover Glass Replacement: 9 단계, 이미지 1/2 Nikon D800 Top LCD Cover Glass Replacement: 9 단계, 이미지 2/2
    • Cut along the right edge of the display.
  10. Nikon D800 Top LCD Cover Glass Replacement: 10 단계, 이미지 1/3 Nikon D800 Top LCD Cover Glass Replacement: 10 단계, 이미지 2/3 Nikon D800 Top LCD Cover Glass Replacement: 10 단계, 이미지 3/3
    • Cut along the left edge of the display.
  11. Nikon D800 Top LCD Cover Glass Replacement: 11 단계, 이미지 1/3 Nikon D800 Top LCD Cover Glass Replacement: 11 단계, 이미지 2/3 Nikon D800 Top LCD Cover Glass Replacement: 11 단계, 이미지 3/3
    • Insert the curved razor blade between the long edge of the LCD and the body of the D800.
    • Use the blade to pry the edge of the glass off the LCD.
  12. Nikon D800 Top LCD Cover Glass Replacement: 12 단계, 이미지 1/2 Nikon D800 Top LCD Cover Glass Replacement: 12 단계, 이미지 2/2
    • Work your blade towards the corner nearest the lens.
    • Again, use the blade to separate the glass from the LCD panel.
  13. Nikon D800 Top LCD Cover Glass Replacement: 13 단계, 이미지 1/3 Nikon D800 Top LCD Cover Glass Replacement: 13 단계, 이미지 2/3 Nikon D800 Top LCD Cover Glass Replacement: 13 단계, 이미지 3/3
    • While lifting up with the razor blade, insert a plastic opening pick underneath the LCD glass.
    • Remove the razor blade.
  14. Nikon D800 Top LCD Cover Glass Replacement: 14 단계, 이미지 1/3 Nikon D800 Top LCD Cover Glass Replacement: 14 단계, 이미지 2/3 Nikon D800 Top LCD Cover Glass Replacement: 14 단계, 이미지 3/3
    • Slide the pick along the top edge of the glass, prying up on the glass against the plastic body as you go.
  15. Nikon D800 Top LCD Cover Glass Replacement: 15 단계, 이미지 1/3 Nikon D800 Top LCD Cover Glass Replacement: 15 단계, 이미지 2/3 Nikon D800 Top LCD Cover Glass Replacement: 15 단계, 이미지 3/3
    • Leave the first opening pick underneath the front-right corner of the glass.
    • Insert a second opening pick underneath the panel from the back-left side of the display.
    • Slide the pick right, prying up the glass panel as you go.
  16. Nikon D800 Top LCD Cover Glass Replacement: 16 단계, 이미지 1/3 Nikon D800 Top LCD Cover Glass Replacement: 16 단계, 이미지 2/3 Nikon D800 Top LCD Cover Glass Replacement: 16 단계, 이미지 3/3
    • Once the glass is mostly separated from the camera, peel the panel completely off the LCD screen.
    • At this point there may be some adhesive tape connecting the glass to the camera. If so, simply pull the glass up until it's free.
  17. Nikon D800 Top LCD Cover Glass Replacement: 17 단계, 이미지 1/3 Nikon D800 Top LCD Cover Glass Replacement: 17 단계, 이미지 2/3 Nikon D800 Top LCD Cover Glass Replacement: 17 단계, 이미지 3/3
    • Using rubbing alcohol and a q-tip, clean the old adhesive strips and any residue off the LCD screen.
  18. Nikon D800 Top LCD Cover Glass Replacement: 18 단계, 이미지 1/3 Nikon D800 Top LCD Cover Glass Replacement: 18 단계, 이미지 2/3 Nikon D800 Top LCD Cover Glass Replacement: 18 단계, 이미지 3/3
    • Carefully align the new LCD protective glass over the display.
    • Lower the left edge of the glass onto the display and press it firmly against the edge of the LCD window.
    • Ease the right edge into place.
  19. Nikon D800 Top LCD Cover Glass Replacement: 19 단계, 이미지 1/3 Nikon D800 Top LCD Cover Glass Replacement: 19 단계, 이미지 2/3 Nikon D800 Top LCD Cover Glass Replacement: 19 단계, 이미지 3/3
    • Press down on the edges of the display to ensure that the glass is strongly-adhered to the LCD.
결승점
다른 9명이 해당 안내서를 완성하였습니다.
Evan Noronha
회원 가입일: 02/05/15
223,424 평판
안내서 168개 작성하였습니다
댓글 한 개
Unfortunately in cases when top screen glass is shuttering, top screen is shuttering to. So for almost everyone only glass replacing is not that case
kvaz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 51
전체 시간: 11,064
