주요 콘텐츠로 건너뛰기
Nikon D90 Flash Bulb Replacement
필요한 것
  1. Nikon D90 Flash Bulb Replacement, Open the Flash: 1 단계, 이미지 1/3 Nikon D90 Flash Bulb Replacement, Open the Flash: 1 단계, 이미지 2/3 Nikon D90 Flash Bulb Replacement, Open the Flash: 1 단계, 이미지 3/3
    • Use a plastic opening tool to lift up the flash.
  2. Nikon D90 Flash Bulb Replacement, Flash Casing Screws: 2 단계, 이미지 1/2 Nikon D90 Flash Bulb Replacement, Flash Casing Screws: 2 단계, 이미지 2/2
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: 3 단계, 이미지 1/3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: 3 단계, 이미지 2/3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: 3 단계, 이미지 3/3
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  4. Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: 4 단계, 이미지 1/2 Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: 4 단계, 이미지 2/2
    • Carefully unclip the bulb casing from the plastic casing using tweezers.
    • Remove the black and white tape on the bulb casing.
    • This tape is what holds the wires and bulb in place.
  5. Nikon D90 Flash Bulb Replacement, Removing the Bulb: 5 단계, 이미지 1/3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: 5 단계, 이미지 2/3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: 5 단계, 이미지 3/3
    • Remove the rubber stopper on the left and right side of the bulb.
    • Separate the rubber stopper from the white and black tape.
    • The bulb can now be slid out and replaced.
    • Be careful not to break the bulb or cut yourself on the broken bulb.
결론
다른 8명이 해당 안내서를 완성하였습니다.
jonothon cawley
회원 가입일: 10/20/14
354 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-7, Duarte Fall 2014 UMass Dartmouth, Team 1-7, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S1G7
3 회원들
안내서 6개 작성하였습니다
2 댓글
thanks for instruction…………really helpfull
hebi - 답글
Hi guys do you know where to get this bulb?please help
Martin Mitter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 37
전체 시간: 6,608
