주요 콘텐츠로 건너뛰기
Nikon D90 Flash Hinge Spring Replacement
필요한 것
  1. Nikon D90 Flash Hinge Spring Replacement, Open the Flash: 1 단계, 이미지 1/3 Nikon D90 Flash Hinge Spring Replacement, Open the Flash: 1 단계, 이미지 2/3 Nikon D90 Flash Hinge Spring Replacement, Open the Flash: 1 단계, 이미지 3/3
    • Use a plastic opening tool to lift up the flash.
  2. Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: 2 단계, 이미지 1/2 Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: 2 단계, 이미지 2/2
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: 3 단계, 이미지 1/3 Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: 3 단계, 이미지 2/3 Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: 3 단계, 이미지 3/3
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  4. Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: 4 단계, 이미지 1/2 Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: 4 단계, 이미지 2/2
    • Using a PH00 screwdriver, loosen the 3.3 mm Phillips screw from the spring.
  5. Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: 5 단계, 이미지 1/2 Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: 5 단계, 이미지 2/2
    • Use a plastic opening tool and carefully pry up the spring arm.
    • Doing this with release the pressure of the spring.
  6. Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: 6 단계, 이미지 1/2 Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: 6 단계, 이미지 2/2
    • Finish removing the screw holding the spring in place.
    • The spring can now be removed and replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Grota
회원 가입일: 10/16/14
586 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-7, Duarte Fall 2014 UMass Dartmouth, Team 1-7, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S1G7
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
These are great tutorials,
I was looking for one on how to fix the pop up flash not locking down,
It was bought second hand and dropped on the logo,
The front panel needed to be replaced,
Now for the Flash that is constantly up.
Any links? jjryzler@gmail.com
Ryad Arlan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 4,132
