주요 콘텐츠로 건너뛰기
Nikon D90 Rear Case Replacement
필요한 것
  1. Nikon D90 Rear Case Replacement, Rear Case: 1 단계, 이미지 1/2 Nikon D90 Rear Case Replacement, Rear Case: 1 단계, 이미지 2/2
    • Slide the eyepiece up and off the viewfinder.
  2. Nikon D90 Rear Case Replacement: 2 단계, 이미지 1/1
    • Using a PH000 screwdriver, remove the two 4.8mm Phillips screws from the back of the viewfinder.
    • Some screws may be JIS. Be wary of this if your PH000 does not feel like it is properly gripping the screws.
  3. Nikon D90 Rear Case Replacement: 3 단계, 이미지 1/1
    • Remove the two 6.4mm Phillips screws on the right side of the camera, near the SD card slot.
  4. Nikon D90 Rear Case Replacement: 4 단계, 이미지 1/1
    • Remove the two 6.4mm Phillips screws on the left side of the camera, near the I/O ports.
  5. Nikon D90 Rear Case Replacement: 5 단계, 이미지 1/1
    • On the bottom of the camera,
    • remove the two 5.3mm Phillips screws
    • and the other two 6.3mm Phillips screws.
  6. Nikon D90 Rear Case Replacement: 6 단계, 이미지 1/3 Nikon D90 Rear Case Replacement: 6 단계, 이미지 2/3 Nikon D90 Rear Case Replacement: 6 단계, 이미지 3/3
    • Using a spudger, separate the bottom panel from the rear case just enough to clear the two clips on the rear casing in the next step.
  7. Nikon D90 Rear Case Replacement: 7 단계, 이미지 1/2 Nikon D90 Rear Case Replacement: 7 단계, 이미지 2/2
    • Lift the rear case off of the back of the camera.
    • Don't pull the casing completely off yet, as the ribbon cables are still connected.
    • Be mindful of the two clips, making sure to keep the bottom panel far enough away to clear them.
  8. Nikon D90 Rear Case Replacement: 8 단계, 이미지 1/1
    • Set the rear casing off to the side so you can access the ZIF connectors.
    • The orientation shown in the picture seems to be the best position for the casing to sit comfortably without stressing the ribbon cable connections.
  9. Nikon D90 Rear Case Replacement: 9 단계, 이미지 1/3 Nikon D90 Rear Case Replacement: 9 단계, 이미지 2/3 Nikon D90 Rear Case Replacement: 9 단계, 이미지 3/3
    • Use a spudger to lift the black tab on the ZIF connector.
    • Disconnect the ribbon cables from their respective ZIF connectors on the logic board.
  10. Nikon D90 Rear Case Replacement: 10 단계, 이미지 1/1
    • Separate the rear casing from the camera.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Ryan Lutz
회원 가입일: 09/27/11
3,008 평판
안내서 3개 작성하였습니다
댓글 2개
good guidance,easy to follow,thanks
ramalingeswarao kaza - 답글
I want to replace my Nikon D90 DSLR bad LCD, this guide will save me from costly repairs.
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 4,197
