주요 콘텐츠로 건너뛰기
Nikon D90 Remplacement de la carte SB/IF
필요한 것
  1. Nikon D90 Remplacement de la carte SB/IF, Remove the bottom cover: 1 단계, 이미지 1/1
    • Remove the three screw in red
    • Remove the three long screw in orange
    • Remove the screw in yellow
    • Use a little of WD40 if the screw is blocked
  2. Nikon D90 Remplacement de la carte SB/IF, Remove the back cover: 2 단계, 이미지 1/3 Nikon D90 Remplacement de la carte SB/IF, Remove the back cover: 2 단계, 이미지 2/3 Nikon D90 Remplacement de la carte SB/IF, Remove the back cover: 2 단계, 이미지 3/3
    • Remove the 4 screw in green
    • Remove the 2 screw in yellow
  3. Nikon D90 Remplacement de la carte SB/IF: 3 단계, 이미지 1/3 Nikon D90 Remplacement de la carte SB/IF: 3 단계, 이미지 2/3 Nikon D90 Remplacement de la carte SB/IF: 3 단계, 이미지 3/3
    • Slacken the grip side of the cover first
    • Remove the cover wholly.
    • Be carefull with the two flex cables
  4. Nikon D90 Remplacement de la carte SB/IF: 4 단계, 이미지 1/3 Nikon D90 Remplacement de la carte SB/IF: 4 단계, 이미지 2/3 Nikon D90 Remplacement de la carte SB/IF: 4 단계, 이미지 3/3
    • Disconnect the FPC of the back cover
    • Toggle up the black plate to free the flex cable
    • Remove the grip cover by rotating
  5. Nikon D90 Remplacement de la carte SB/IF, Disconnect all the cables - part 1/3: 5 단계, 이미지 1/3 Nikon D90 Remplacement de la carte SB/IF, Disconnect all the cables - part 1/3: 5 단계, 이미지 2/3 Nikon D90 Remplacement de la carte SB/IF, Disconnect all the cables - part 1/3: 5 단계, 이미지 3/3
    • Toggle up the black plate and disconnect the flex cable
    • Toggle up the white plate and disconnect the flex cable
    • Push up the right slide of the connector to free it
  6. Nikon D90 Remplacement de la carte SB/IF, Disconnect all the cables - part 2/3: 6 단계, 이미지 1/1
    • Push up the bottom of the connector to free it
  7. Nikon D90 Remplacement de la carte SB/IF, Detach the protection plate: 7 단계, 이미지 1/3 Nikon D90 Remplacement de la carte SB/IF, Detach the protection plate: 7 단계, 이미지 2/3 Nikon D90 Remplacement de la carte SB/IF, Detach the protection plate: 7 단계, 이미지 3/3
    • Remove the six screws to free the protection plate
    • Disconnect the white cables
    • Disconnect the microphone Cable
  8. Nikon D90 Remplacement de la carte SB/IF, Disconnect all cables - Part 3/3: 8 단계, 이미지 1/3 Nikon D90 Remplacement de la carte SB/IF, Disconnect all cables - Part 3/3: 8 단계, 이미지 2/3 Nikon D90 Remplacement de la carte SB/IF, Disconnect all cables - Part 3/3: 8 단계, 이미지 3/3
    • Disconnect the speaker cable
    • Remove the two screws to free the PCB
    • Toggle th PCB from Left to Right
  9. Nikon D90 Remplacement de la carte SB/IF, Disconnect the cable on the bottom of the PCB: 9 단계, 이미지 1/1
    • Disconnect the black cables
  10. Nikon D90 Remplacement de la carte SB/IF, Free the IF/SB PCB: 10 단계, 이미지 1/2 Nikon D90 Remplacement de la carte SB/IF, Free the IF/SB PCB: 10 단계, 이미지 2/2
    • Push the IF/SB PCB
    • Unsolder the 3 Wires ( Red, Black, Orange )
결론
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
JOLY
회원 가입일: 03/06/16
182 평판
안내서 1개 작성함
Nexurium - Bastien JOLY Nexurium - Bastien JOLY 회원
Business
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 22
전체 시간: 2,211
