주요 콘텐츠로 건너뛰기
Nikon D90 Tripod Thread Plate Replacement
필요한 것
  1. Nikon D90 Tripod Thread Plate Replacement, Bottom Casing: 1 단계, 이미지 1/1
    • Turn the camera so the bottom casing is facing up.
  2. Nikon D90 Tripod Thread Plate Replacement, Removing  Screws from the Bottom Casing: 2 단계, 이미지 1/2 Nikon D90 Tripod Thread Plate Replacement, Removing  Screws from the Bottom Casing: 2 단계, 이미지 2/2
    • Next, use a PH00 screwdriver to remove the screws from the bottom casing.
    • Remove the four 5.3 mm Phillips screws.
    • Remove the three other 6.3 mm Phillips screws.
    • Be careful not to strip the screws.
  3. Nikon D90 Tripod Thread Plate Replacement, Removing the Bottom Case: 3 단계, 이미지 1/2 Nikon D90 Tripod Thread Plate Replacement, Removing the Bottom Case: 3 단계, 이미지 2/2
    • Next, use a plastic opening tool and carefully pop off the bottom case.
    • Then, lift and remove the bottom case.
  4. Nikon D90 Tripod Thread Plate Replacement, Removing Screws: 4 단계, 이미지 1/2 Nikon D90 Tripod Thread Plate Replacement, Removing Screws: 4 단계, 이미지 2/2
    • Next, remove the five 5.3 mm Phillips screws.
  5. Nikon D90 Tripod Thread Plate Replacement, Taking Out the Plate: 5 단계, 이미지 1/2 Nikon D90 Tripod Thread Plate Replacement, Taking Out the Plate: 5 단계, 이미지 2/2
    • Now use a plastic opening tool and carefully pop off the metal tripod thread plate.
    • Be careful to not pull on any wires under the thread plate.
  6. Nikon D90 Tripod Thread Plate Replacement, Removing the Plate from the Camera: 6 단계, 이미지 1/2 Nikon D90 Tripod Thread Plate Replacement, Removing the Plate from the Camera: 6 단계, 이미지 2/2
    • Carefully wiggle the yellow metal tab to remove the plate.
    • Be careful not to pull hard and damage any other pieces.
결론
Andrew
회원 가입일: 10/24/14
180 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-7, Duarte Fall 2014 UMass Dartmouth, Team 1-7, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S1G7
3 회원들
안내서 6개 작성하였습니다
댓글 2개
كاميرا لاتعمل تماما شرت كت
hamdyalchip - 답글
Thanks for the guide, this gives me a good idea how to go about this on a D3000.
However: “Next, use a PH00 screwdriver to remove the screws from the bottom casing. Remove the Phillips screws. Be careful not to strip the screws.”
Nikon does not use Phillips screws, they are JIS (Japanese Industrial Standard) screws.
They are not the same and to not have the “cam out” feature of Phillips which is designed to prevent heads being sheared off.
The easiest way to strip JIS screws is by using a Phillips screwdriver.
Use the correct JIS screwdriver and you’ll have no problem.
Cheers
Mark Roy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 19
전체 시간: 3,559
