주요 콘텐츠로 건너뛰기
Nikon L310 Camera LCD Broken Replacement
필요한 것
  1. Nikon L310 Camera LCD Broken Replacement, LCD Broken: 1 단계, 이미지 2개 중 1개 Nikon L310 Camera LCD Broken Replacement, LCD Broken: 1 단계, 이미지 2개 중 2개
    • Here we have the Nikon L310 with the LCD and outer window broken. First of all, I start to remove the screws, but be careful, because they have different lenght.
  2. Nikon L310 Camera LCD Broken Replacement: 2 단계, 이미지 3개 중 1개 Nikon L310 Camera LCD Broken Replacement: 2 단계, 이미지 3개 중 2개 Nikon L310 Camera LCD Broken Replacement: 2 단계, 이미지 3개 중 3개
    • First, we will remove the screws from the bottom side. These only 3. Remember the sizes!
    • Then, the 2 screws of the Right side
    • And finally, the screw above the USB port, on the Left side.
  3. Nikon L310 Camera LCD Broken Replacement: 3 단계, 이미지 2개 중 1개 Nikon L310 Camera LCD Broken Replacement: 3 단계, 이미지 2개 중 2개
    • Now, its time to open the flash, and remove the screw that is allocated inside.
    • Remove the protector, and you will find a silver screw. Remove it.
  4. Nikon L310 Camera LCD Broken Replacement: 4 단계, 이미지 3개 중 1개 Nikon L310 Camera LCD Broken Replacement: 4 단계, 이미지 3개 중 2개 Nikon L310 Camera LCD Broken Replacement: 4 단계, 이미지 3개 중 3개
    • Now, you can separate the rear plastic frame, carefully.
    • As you can see, the entire plastic frame cames out.
    • And here it is, the display!
  5. Nikon L310 Camera LCD Broken Replacement: 5 단계, 이미지 3개 중 1개 Nikon L310 Camera LCD Broken Replacement: 5 단계, 이미지 3개 중 2개 Nikon L310 Camera LCD Broken Replacement: 5 단계, 이미지 3개 중 3개
    • Lift carefully the LCD module, and you will see that is connected by a FPC connector.
    • Release the tab, and unplug the flex cable.
    • Insert the new flex cable and install the LCD on its frame.
    • DONT forget to remove the protective film from the NEW LCD!!
  6. Nikon L310 Camera LCD Broken Replacement: 6 단계, 이미지 1개 중 1개
    • Re-assembly all the parts, and put back the screws. The reparation is DONE! Here you can see the display fixed and the outer window replaced by methacrylate part made by myself ( I have one Dremel... )
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jaime
회원 가입일: 11/05/13
3,333 평판
안내서 4개를 작성함
6가이드 댓글
Hi! I dropped my camera Nikon B500 and now the screen is black. The display shows and you can view picture plus menu. But you can not see when you want to take a picture. What do you think it is? And could I fix it myself? Thank you so much for helping. You can email me at hazel-04@hotmail.com
hazel-04 - 답글
What size screwdrivers do I need for this job? And where would I get them?? Thanks.
arlene.rodriguez - 답글
How much is the screen if I wanna buy it?
Woli Atunbi - 답글
How much is the screen for L310 coolpix I need 1
Woli Atunbi - 답글
So everything went smoothly, except the part when I separated the rear frame, it was way too hard, all screws removed but I feel like I'm gonna break it if I try harder.
Soge T.Sơn - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 85
전체 시간: 5,955
