주요 콘텐츠로 건너뛰기
Nikon N2000 (F301) Communication Board Replacement
필요한 것
  1. Nikon N2000 (F301) Communication Board Replacement, Lens Mount: 1 단계, 이미지 1/1
    • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  2. Nikon N2000 (F301) Communication Board Replacement: 2 단계, 이미지 1/1
    • Remove lens mount from the camera.
    • Be careful not to lose any of the three loose pieces that are under the lens mount.
  3. Nikon N2000 (F301) Communication Board Replacement, Communication Board: 3 단계, 이미지 1/1
    • Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
    • Make sure you remember the orientation of the metal ring so that it is easier to put back in the device later.
  4. Nikon N2000 (F301) Communication Board Replacement: 4 단계, 이미지 1/1
    • Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
  5. Nikon N2000 (F301) Communication Board Replacement: 5 단계, 이미지 1/3 Nikon N2000 (F301) Communication Board Replacement: 5 단계, 이미지 2/3 Nikon N2000 (F301) Communication Board Replacement: 5 단계, 이미지 3/3
    • Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
  6. Nikon N2000 (F301) Communication Board Replacement: 6 단계, 이미지 1/1
    • Remove the front case from the camera.
    • There is a black plastic ring in the case. Be sure not to remove it, as it can be difficult to put back.
  7. Nikon N2000 (F301) Communication Board Replacement: 7 단계, 이미지 1/1
    • Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
  8. Nikon N2000 (F301) Communication Board Replacement: 8 단계, 이미지 1/1
    • Desolder the wires and remove them from the communication board.
    • Note: If you are unfamiliar with soldering techniques, click here for a guide.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Zachary Phillips
회원 가입일: 04/08/11
247 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011 회원
CPSU-GARNER-S11S25G26
3 회원들
안내서 12개 작성하였습니다
댓글 3개
Doesn't work for the 301, although it looks similar I can't find any way to remove the top or the front case
John Chapple - 답글
The F301 and N2000 are identical, so the guide should work. In this guide the top case isn't removed, as the film rewind knob is preventing it from coming off completely, and instead just lifted with the bit of leeway the popped up rewind knob provides.
Miles Kosik -
Is there a way to remove the plasticzek top cover, as comment above says, the knobs prevents me from removing this part. My plastic cover is broken and I want to change it for a new one, is there a way?
Filip N - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 64
전체 시간: 6,120
