소개
Back case acts as a door to access change out film. It can be easily removed from the device and replaced if it becomes cracked or otherwise unusable.
    • In this guide we will refer to 'left' and 'right' as though the camera is facing away from you.
    • Pull up on the film rewind lever on the top left of the camera to release the back door.
    • Once the door is released, open it completely.
  1. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    • Locate the silver tab on the inside of the door hinge. Slide this down to free the hinge and remove it from the camera.
결론
Zachary Phillips
회원 가입일: 2011년 04월 08일
205 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011 회원
CPSU-GARNER-S11S25G26
3 회원들
안내서 7개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 2,199
