소개
If there is a power problem, you may need to reattach wires to the battery compartment or replace it completely. If the problem is Corrosion, just see the guide on corrosion.
필요한 것
Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
