주요 콘텐츠로 건너뛰기
Nikon N2000 (F301) Battery Compartment Replacement
필요한 것
    • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
    • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
  1. Nikon N2000 (F301) Battery Compartment Replacement: 2 단계, 이미지 1/1
    • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  2. Nikon N2000 (F301) Battery Compartment Replacement: 3 단계, 이미지 1/1
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  3. Nikon N2000 (F301) Battery Compartment Replacement: 4 단계, 이미지 1/1
    • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
  4. Nikon N2000 (F301) Battery Compartment Replacement: 5 단계, 이미지 1/1
    • Remove the battery compartment from the camera.
    • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Zachary Phillips
회원 가입일: 04/08/11
247 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011 회원
CPSU-GARNER-S11S25G26
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 30
30일 전: 147
전체 시간: 17,218
