소개
The communication board sends information about the aperture and focus of the lens. If you are having trouble with focus or aperture, then there may be a problem with the communication board.
부품
부품은 필요하지 않습니다.
  1. Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
    • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  2. Remove lens mount from the camera.
    • Remove lens mount from the camera.
    • Be careful not to lose any of the three loose pieces that are under the lens mount.
  3. Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
    • Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
    • Make sure you remember the orientation of the metal ring so that it is easier to put back in the device later.
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
    • Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
  6. Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all). Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all). Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
    • Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
  7. Remove the front case from the camera.
    • Remove the front case from the camera.
    • There is a black plastic ring in the case. Be sure not to remove it, as it can be difficult to put back.
  8. Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
    • Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
  9. Desolder the wires and remove them from the communication board.
    • Desolder the wires and remove them from the communication board.
    • Note: If you are unfamiliar with soldering techniques, click here for a guide.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Zachary Phillips
회원 가입일: 2011년 04월 08일
205 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011 회원
CPSU-GARNER-S11S25G26
3 회원들
안내서 7개 작성하였습니다
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 22
전체 시간: 4,145
