주요 콘텐츠로 건너뛰기
Nikon N2000 (F301) Battery Compartment Replacement
필요한 것
    • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
    • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
  1. Nikon N2000 (F301) Battery Compartment Replacement: 2 단계, 이미지 1개 중 1개
    • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  2. Nikon N2000 (F301) Battery Compartment Replacement: 3 단계, 이미지 1개 중 1개
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  3. Nikon N2000 (F301) Battery Compartment Replacement: 4 단계, 이미지 1개 중 1개
    • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
  4. Nikon N2000 (F301) Battery Compartment Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the battery compartment from the camera.
    • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Zachary Phillips
회원 가입일: 04/08/11
280 평판
안내서 5개를 작성함
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011 회원
CPSU-GARNER-S11S25G26
3 회원들
안내서 12개를 작성함
2가이드 댓글
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - 답글
Ok, and so when the battery compartment is out, then what? (And does it really need to be taken out for cleaning..?)
MarkC - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 29
지난 30일: 126
전체 시간: 19,479
