소개
If you are having trouble mounting the lens and you are sure you have the correct lens type (see the camera manual for types of lenses that can be used), then use this guide to assist with replacing the lens mount.
필요한 것
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
where can I order the "3 loose pieces and the ring that goes in under the bayonet mount?
