주요 콘텐츠로 건너뛰기
Nikon N80 Lens Mount (aka Bayonet Mount) Replacement
필요한 것
  1. Nikon N80 Lens Mount (aka Bayonet Mount) Replacement, Lens Mount (aka Bayonet Mount): 1 단계, 이미지 1/1
    • Make sure the On/Off switch is in the Off position.
  2. Nikon N80 Lens Mount (aka Bayonet Mount) Replacement: 2 단계, 이미지 1/1
    • Place the camera so the lens is facing up.
    • If your camera has a lens on, remove it by pushing and holding the lens release button and turning the lens clockwise until it comes off.
  3. Nikon N80 Lens Mount (aka Bayonet Mount) Replacement: 3 단계, 이미지 1/1
    • Use a PH00 Phillips screwdriver to remove the five 4.8mm screws on the silver lens mount.
  4. Nikon N80 Lens Mount (aka Bayonet Mount) Replacement: 4 단계, 이미지 1/1
    • Remove the old lens mount and place the new one on.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maegan Viloria
회원 가입일: 09/14/15
717 평판
안내서 5개 작성하였습니다
CSU Fullerton, Team 1-7, Bruce Fall 2015 CSU Fullerton, Team 1-7, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 19
30일 전: 47
전체 시간: 1,982
