주요 콘텐츠로 건너뛰기
Nikon N80 Viewfinder Replacement
필요한 것
  1. Nikon N80 Viewfinder Replacement, Viewfinder: 1 단계, 이미지 1/1
    • Make sure the On/Off switch is in the Off position.
  2. Nikon N80 Viewfinder Replacement: 2 단계, 이미지 1/3 Nikon N80 Viewfinder Replacement: 2 단계, 이미지 2/3 Nikon N80 Viewfinder Replacement: 2 단계, 이미지 3/3
    • Remove the four 4.8mm screws on the top section of the camera using a PH00 Phillips screwdriver.
    • Two are located by the viewfinder and and the other two are on each side of the camera.
  3. Nikon N80 Viewfinder Replacement: 3 단계, 이미지 1/2 Nikon N80 Viewfinder Replacement: 3 단계, 이미지 2/2
    • Rotate the camera so the bottom plate is accessible.
    • Remove the seven 4.8mm screws on the bottom plate of the camera using a PH00 Phillips screwdriver.
    • Separate the bottom plate.
  4. Nikon N80 Viewfinder Replacement: 4 단계, 이미지 1/1
    • Remove the five silver 4.8mm screws on the lens mount using a PH00 Phillips screwdriver.
    • Extract the lens mount.
  5. Nikon N80 Viewfinder Replacement: 5 단계, 이미지 1/3 Nikon N80 Viewfinder Replacement: 5 단계, 이미지 2/3 Nikon N80 Viewfinder Replacement: 5 단계, 이미지 3/3
    • Remove the seven 4.8mm screws on front camera plate using a PH00 Phillips screwdriver.
    • One is located on the battery chamber side of the camera, two are next to the film door release lever, two are located below the "Nikon" logo, and the last two are located above the "Nikon" logo in the Speedlight compartment.
  6. Nikon N80 Viewfinder Replacement: 6 단계, 이미지 1/1
    • Separate the three front camera plates from the camera.
  7. Nikon N80 Viewfinder Replacement: 7 단계, 이미지 1/1
    • Gently disconnect the top section of the camera from the body.
    • Don't pull the top section off too hard or the wire and ribbon within the camera may disconnect.
  8. Nikon N80 Viewfinder Replacement: 8 단계, 이미지 1/1
    • Remove the two 4.8mm screws next to the viewfinder with a PH00 Phillips screwdriver.
  9. Nikon N80 Viewfinder Replacement: 9 단계, 이미지 1/2 Nikon N80 Viewfinder Replacement: 9 단계, 이미지 2/2
    • Pull out the viewfinder gently.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maegan Viloria
회원 가입일: 09/14/15
717 평판
안내서 5개 작성하였습니다
CSU Fullerton, Team 1-7, Bruce Fall 2015 CSU Fullerton, Team 1-7, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G7
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
This is a great guide, thank you!
Test Test - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 45
전체 시간: 2,538
