주요 콘텐츠로 건너뛰기
Ninja Coffee Bar® Single-Serve System Water Heater Replacement
필요한 것
  1. Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Valve Tubes: 1 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Valve Tubes: 1 단계, 이미지 2/2
    • Remove the eight 6 mm screws using the Phillips #1 screwdriver.
    • Remove the bottom cover.
  2. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 2 단계, 이미지 1/1
    • Remove the three 6 mm screws with the Phillips #1 screwdriver.
    • Remove the plastic cover.
  3. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 3 단계, 이미지 1/1
    • Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
  4. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 4 단계, 이미지 1/1
    • Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
  5. Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Water Heater: 5 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Water Heater: 5 단계, 이미지 2/2
    • Unscrew the four 6mm #1 Phillips head screws from the underside of the basket area.
    • Remove the single 6mm #1 Phillips-head screw from the side of the unit.
  6. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 6 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 6 단계, 이미지 2/2
    • Slowly pry the upper cover away from the unit on top of the brew basket, and near the base of the water reservoir along the side of the upper cover.
  7. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 7 단계, 이미지 1/1
    • Separate hose from upper nozzle by squeezing the clamp and pulling the hose down slightly.
  8. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 8 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 8 단계, 이미지 2/2
    • Using a #1 Phillips head screwdriver with an extension, remove three 6mm screws holding the heater to the unit.
  9. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 9 단계, 이미지 1/1
    • Remove heater from unit.
  10. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 10 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: 10 단계, 이미지 2/2
    • Squeeze clip and separate signal wiring.
    • Using wire stripper/crimping tool, uncrimp wiring connectors
    • Wiring connectors are sealed together making them difficult to disconnect. Cutting and rewiring should be considered.
결론
CJ Berg
회원 가입일: 11/05/18
444 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G4
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Where can I buy the water heater?
lrstorey1 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 1,057
