주요 콘텐츠로 건너뛰기
Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement
필요한 것
  1. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement, Drip Stop Toggle and Brew Basket: 1 단계, 이미지 1/1
    • Slide the brew baskets to the open position.
  2. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 2 단계, 이미지 1/1
    • Remove three 6mm screws with Phillips head screw driver.
  3. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 3 단계, 이미지 1/3 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 3 단계, 이미지 2/3 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using needle nose tweezers, push the bottom of the pin up from behind the brew basket
    • Pull the pin out.
  4. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 4 단계, 이미지 1/1
    • Remove brew basket from swinging basket holder
  5. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 5 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 5 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove one 6mm screw from the drip stop toggle.
    • Remove the drip stop toggle.
결론
Naser Aldousari
회원 가입일: 10/10/17
310 평판
안내서 3개 작성하였습니다
USF Tampa, Team S13-G69, Cagle Fall 2017 USF Tampa, Team S13-G69, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G69
4 회원들
안내서 3개 작성하였습니다
댓글 3개
Can you provide more detail regarding the small spring that you provide the warning for? The one that needs to stay in place. If it does fall out, how can not be fixed or rather where does not go?
Dani - 답글
Agree! The spring NEEDS to be resting vertically in between the two clips, in my case, these have worn and the spring came out of seat. It needed to be refastened and the five beeps, “of death” have disappeared and my coffeepot functions again!
Marcus Martinez - 답글
* this works on the ninja coffee bar larger system as well
Marcus Martinez -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 45
전체 시간: 6,967
