주요 콘텐츠로 건너뛰기
Ninja Coffee Bar® Single-Serve System Frother Replacement
필요한 것
  1. Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: 1 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: 1 단계, 이미지 2/2
    • Remove four 6mm #1 Phillips head screws from under the basket area.
    • Remove the single 6mm #1 Phillips head screw from the side of the unit.
  2. Ninja Coffee Bar® Single-Serve System Frother Replacement: 2 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Frother Replacement: 2 단계, 이미지 2/2
    • Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
  3. Ninja Coffee Bar® Single-Serve System Frother Replacement: 3 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Frother Replacement: 3 단계, 이미지 2/2
    • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
    • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  4. Ninja Coffee Bar® Single-Serve System Frother Replacement: 4 단계, 이미지 1/3 Ninja Coffee Bar® Single-Serve System Frother Replacement: 4 단계, 이미지 2/3 Ninja Coffee Bar® Single-Serve System Frother Replacement: 4 단계, 이미지 3/3
    • Pinch power connector and pull lighly to separate.
    • Pull motor straight up to separate from unit.
결론
CJ Berg
회원 가입일: 11/05/18
444 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G4
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
clarkwolfe - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 15
전체 시간: 1,485
