주요 콘텐츠로 건너뛰기
Ninja Coffee Bar® Single-Serve System Power Cable Replacement
필요한 것
  1. Ninja Coffee Bar® Single-Serve System Power Cable Replacement, Power Cable: 1 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Power Cable Replacement, Power Cable: 1 단계, 이미지 2/2
    • Unscrew the eight 6mm #1 Phillips head screws off the bottom panel.
    • Lift lower panel up while passing the power cord through the opening.
  2. Ninja Coffee Bar® Single-Serve System Power Cable Replacement: 2 단계, 이미지 1/1
    • Loosen two 6mm #1 Phillips head and remove clamp holding power cable.
  3. Ninja Coffee Bar® Single-Serve System Power Cable Replacement: 3 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Power Cable Replacement: 3 단계, 이미지 2/2
    • Pull the power cable out exposing the two crimped ends.
    • Using a wire stripper/crimping tool, uncrimp wires.
    • Wiring connectors are sealed together making them difficult to disconnect. Cutting and rewiring should be considered.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
CJ Berg
회원 가입일: 11/05/18
444 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 440
