주요 콘텐츠로 건너뛰기
Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement
필요한 것
  1. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement, Valve Tubes: 1 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement, Valve Tubes: 1 단계, 이미지 2/2
    • Remove the eight 6 mm screws using the Phillips #1 screwdriver.
    • Remove the bottom cover.
  2. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: 2 단계, 이미지 1/1
    • Remove the three 6 mm screws with the Phillips #1 screwdriver.
    • Remove the plastic cover.
  3. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: 3 단계, 이미지 1/1
    • Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
  4. Ninja Coffee Bar® Single-Serve System Valve Tubes Replacement: 4 단계, 이미지 1/1
    • Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
결론
Naser Aldousari
회원 가입일: 10/10/17
310 평판
안내서 3개 작성하였습니다
USF Tampa, Team S13-G69, Cagle Fall 2017 USF Tampa, Team S13-G69, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G69
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 882
