소개
Changing the tubes when the Ninja Coffee Bar® Single-Serve System leaks water from the bottom will require some time but can fix a few problems. Ensure the device is in a secure open area where you will not lose any screws because they are small. You will want the magnetic pad provided in the iFixit tool kit. Warning: be careful when removing the protective plate because many wires cannot be disconnected.
Before beginning the repair, turn off the coffee maker and unplug the device from the power outlet.
필요한 것
Remove the eight 6 mm screws using the Phillips #1 screwdriver.
Remove the bottom cover.
