소개
If your normally piping hot cup of coffee is coming out at room temperature then the water heater may be to blame. This replacement involves removing a number of small screws so it may be a good idea to have the iFixit magnet pad nearby. Follow this guide to replace your device’s water heater and restore heat to your Ninja Coffee Bar.
필요한 것
Remove the eight 6 mm screws using the Phillips #1 screwdriver.
Remove the bottom cover.
Unscrew the four 6mm #1 Phillips head screws from the underside of the basket area.
Remove the single 6mm #1 Phillips-head screw from the side of the unit.
