주요 콘텐츠로 건너뛰기
Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement
필요한 것
  1. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement, Valve: 1 단계, 이미지 1/1
    • Unscrew eight 6mm screws with Phillips head #1 screwdriver
    • Remove bottom cover
  2. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: 2 단계, 이미지 1/1
    • Unscrew three 6mm screws with Phillips head #1 screwdriver
    • Remover tube protection plate
  3. Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: 3 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Water Regulating Valve Replacement: 3 단계, 이미지 2/2
    • Detach valve tubes from valve by squeezing pins and pull tubes away from valve
결론
다른 2명이 해당 안내서를 완성하였습니다.
Naser Aldousari
회원 가입일: 10/10/17
310 평판
안내서 3개 작성하였습니다
USF Tampa, Team S13-G69, Cagle Fall 2017 USF Tampa, Team S13-G69, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G69
4 회원들
안내서 3개 작성하였습니다
댓글 2개
Where can I get the replacement water valve?
Mark Peters - 답글
Anyone have a source for the valve?
ErrorCode67 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 1,918
