주요 콘텐츠로 건너뛰기
Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement
필요한 것
  1. Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement, Water Reservoir Clip: 1 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement, Water Reservoir Clip: 1 단계, 이미지 2/2
    • Remove single 6mm #1 Phillips head screw from the side of the unit and four 6mm screws from under the basket area.
  2. Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement: 2 단계, 이미지 1/2 Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement: 2 단계, 이미지 2/2
    • Gently pry the upper panel up from the unit.
  3. Ninja Coffee Bar® Single-Serve System Water Reservoir Hanger Replacement: 3 단계, 이미지 1/1
    • Inside the panel, remove the two 6mm #1 Phillips head screws. Remove and replace water reservoir clip as necessary.
결론
CJ Berg
회원 가입일: 11/05/18
444 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 801
