주요 콘텐츠로 건너뛰기
Ninja Coffee Bar CF080 Heated Plate Replacement
필요한 것
  1. Ninja Coffee Bar CF080 Heated Plate Replacement, Heated Plate: 1 단계, 이미지 1/1
    • Face the machine bottom towards you.
  2. Ninja Coffee Bar CF080 Heated Plate Replacement: 2 단계, 이미지 1/2 Ninja Coffee Bar CF080 Heated Plate Replacement: 2 단계, 이미지 2/2
    • Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
    • Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
  3. Ninja Coffee Bar CF080 Heated Plate Replacement: 3 단계, 이미지 1/3 Ninja Coffee Bar CF080 Heated Plate Replacement: 3 단계, 이미지 2/3 Ninja Coffee Bar CF080 Heated Plate Replacement: 3 단계, 이미지 3/3
    • With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
  4. Ninja Coffee Bar CF080 Heated Plate Replacement: 4 단계, 이미지 1/3 Ninja Coffee Bar CF080 Heated Plate Replacement: 4 단계, 이미지 2/3 Ninja Coffee Bar CF080 Heated Plate Replacement: 4 단계, 이미지 3/3
    • Remove the bottom board with moderate force.
  5. Ninja Coffee Bar CF080 Heated Plate Replacement: 5 단계, 이미지 1/1
    • Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
    • Four screws on each side, two silver secures to remove the securers, located on the sliver bar holding the heated plate (one on each end).
  6. Ninja Coffee Bar CF080 Heated Plate Replacement: 6 단계, 이미지 1/1
    • Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
    • The silver bar will fall off once screws are removed.
  7. Ninja Coffee Bar CF080 Heated Plate Replacement: 7 단계, 이미지 1/2 Ninja Coffee Bar CF080 Heated Plate Replacement: 7 단계, 이미지 2/2
    • Remove the heated plate from the machine with easy glide.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elizabeth Nguyen
회원 가입일: 09/11/17
416 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team S1-G1, Bruce Fall 2017 CSU Fullerton, Team S1-G1, Bruce Fall 2017 회원
CSUF-BRUCE-F17S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Where do you get a replacement plate at?
Timothy Sick - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 13
전체 시간: 815
