주요 콘텐츠로 건너뛰기
Ninja Kitchen System Pulse Fan Replacement
필요한 것
  1. Ninja Kitchen System Pulse Fan Replacement, Base Disassembly: 1 단계, 이미지 1/1
    • Take out the three 15 mm Phillips #1 screws.
    • Remove the 15mm T10 screw.
    • Place the 4 screws on the magnetic mat.
  2. Ninja Kitchen System Pulse Fan Replacement: 2 단계, 이미지 1/1
    • Remove the gray base by lifting upwards and placing to the side.
  3. Ninja Kitchen System Pulse Fan Replacement, Fan: 3 단계, 이미지 1/1
    • Remove the central 15 mm length screw, you must hold the fan in place and use a flat head screw driver, twisting counterclockwise.
    • Place this screw on the magnetic mat.
  4. Ninja Kitchen System Pulse Fan Replacement: 4 단계, 이미지 1/2 Ninja Kitchen System Pulse Fan Replacement: 4 단계, 이미지 2/2
    • Remove the fan from the motor by gently pulling upwards.
    • Be careful as to not damage any wires when removing the fan.
    • Set the fan to the side.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Cameron Just
회원 가입일: 01/20/16
391 평판
안내서 3개 작성하였습니다
USF Tampa, Team 15-1, Remmell Spring 2016 USF Tampa, Team 15-1, Remmell Spring 2016 회원
USFT-REMMELL-S16S15G1
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 22
전체 시간: 882
