주요 콘텐츠로 건너뛰기
Ninja NJ600 Fan Replacement
필요한 것
  1. Ninja NJ600 Fan Replacement, Blender Base Cover: 1 단계, 이미지 1/2 Ninja NJ600 Fan Replacement, Blender Base Cover: 1 단계, 이미지 2/2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Fan Replacement: 2 단계, 이미지 1/2 Ninja NJ600 Fan Replacement: 2 단계, 이미지 2/2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Fan Replacement: 3 단계, 이미지 1/3 Ninja NJ600 Fan Replacement: 3 단계, 이미지 2/3 Ninja NJ600 Fan Replacement: 3 단계, 이미지 3/3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Fan Replacement, Fan: 4 단계, 이미지 1/1
    • Hold the fan steady and use a wrench or pliers to remove the nut in the image.
    • The fan is sharp. Use caution when handling with bare hands.
    • A towel or gloves may be useful when holding the fan for this step.
  5. Ninja NJ600 Fan Replacement: 5 단계, 이미지 1/1
    • Hold the fan and use the flathead 4.0 screwdriver to loosen the washer.
    • The fan is sharp, use caution when handling with bare hands.
    • You may use a towel or gloves to avoid handling the fan with your bare hands.
  6. Ninja NJ600 Fan Replacement: 6 단계, 이미지 1/2 Ninja NJ600 Fan Replacement: 6 단계, 이미지 2/2
    • Slide the washer and fan off of the screw.
결론
Ryan Heller
회원 가입일: 04/01/15
107 평판
안내서 1개 작성함
Cal Poly, Team 24-2, Lancaster Spring 2015 Cal Poly, Team 24-2, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S24G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 1,378
