주요 콘텐츠로 건너뛰기
Ninja Professional BL610 Circuit Board Replacement
필요한 것
  1. Ninja Professional BL610 Circuit Board Replacement, Circuit Board: 1 단계, 이미지 1개 중 1개
    • Remove six screws (13mm long, 6mm head diameter) from bottom of the blender using a Phillips #2 screwdriver
  2. Ninja Professional BL610 Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove six screws (12mm long, 6mm head diameter) from component housing using Phillips #2 screwdriver.
  3. Ninja Professional BL610 Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
    • Remove six screws (9mm long, 2mm head diameter) from component housing using Phillips #2 screwdriver
  4. Ninja Professional BL610 Circuit Board Replacement: 4 단계, 이미지 1개 중 1개
    • Locate the black and red wire that connect to the circuit. Locate where they are soldered on the back.
  5. Ninja Professional BL610 Circuit Board Replacement: 5 단계, 이미지 1개 중 1개
    • Desolder both wires from the solder pads shown.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Rosniel Castro
회원 가입일: 09/27/17
482 평판
안내서 4개를 작성함
USF Tampa, Team S14-G3, Boczar Fall 2017 USF Tampa, Team S14-G3, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G3
4 회원들
안내서 6개를 작성함
댓글 8개
hi , my friend just recently purchased a Model B611 from Canada and brought it home here in the Philippines. In all of her excitement failed to first check for the working voltage, and plugged it in to a 220-240 volt outlet, and the rest is history. I tried comparing the board on your illustration, and it seems like that their one and the same, just want to verify.My board is showing BL610 (K01-BC-11-02) would it be safe to try to purchase the board showing here on your guide for the model B610? and where could I order one, if I choose to replace the whole board. Another option would be to try to replace the blown parts, varistor, film capacitor and the transistor
alfred leung - 답글
Looks like I found the solution to my own problem, instead of attempting to swap out the board , I replaced the burnt out varistor, then proceeded to add on jumper wires to bridge the damaged plating around the varistor and power lead in. The varistor actually saved the day , since no fuse was included in the board design. Blender is now up and running. Also added a sticker to remind the user that the unit is a 120v only appliance.
alfred leung -
Ninja often puts a trace fuse in on high volume products.
Liam Fionlhiason -
Followed the disassembly instruction, helped me a lot!!!
alfred leung - 답글
Please, were I can find a new board to buy?
My Blender is a BL-710 MW30 120V NFB 1000W, but the circuit board is “BL610 (K01-BC-11-02) “.
Thank for any help.
Jean
Jean Ligocki - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 36
지난 30일: 79
전체 시간: 2,614
