주요 콘텐츠로 건너뛰기
Ninja Professional Blender 1100 watt Blade Replacement
  1. Ninja Professional Blender 1100 watt Blade Replacement, Blades: 1 단계, 이미지 1/1
    • Unplug blender.
    • Remove the pitcher from the base by turning it counter clockwise so the pitcher is not aligned with the arrows on the base.
  2. Ninja Professional Blender 1100 watt Blade Replacement: 2 단계, 이미지 1/2 Ninja Professional Blender 1100 watt Blade Replacement: 2 단계, 이미지 2/2
    • Press the release button on top of the lid.
    • Pull the lid off.
    • Use both hands when taking off the lid. You may need to pull hard if there is water between the lid and the pitcher, which will create a tight suction.
  3. Ninja Professional Blender 1100 watt Blade Replacement: 3 단계, 이미지 1/1
    • Blades are very sharp.
    • Use one hand to pull the blade housing out of the pitcher while using the other hand to hold onto the pitcher handle.
  4. Ninja Professional Blender 1100 watt Blade Replacement: 4 단계, 이미지 1/2 Ninja Professional Blender 1100 watt Blade Replacement: 4 단계, 이미지 2/2
    • Insert the new blade house into the pitcher and align it so it fits onto the mounting gear.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Elizabeth Hernandez
회원 가입일: 09/14/15
315 평판
안내서 1개 작성함
CSU Fullerton, Team 1-1, Bruce Fall 2015 CSU Fullerton, Team 1-1, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G1
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 78
전체 시간: 3,859
