주요 콘텐츠로 건너뛰기
Ninja Professional Blender BL660 Blender Base Replacement
필요한 것
  1. Ninja Professional Blender BL660 Blender Base Replacement, Blender Base: 1 단계, 이미지 1/2 Ninja Professional Blender BL660 Blender Base Replacement, Blender Base: 1 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
    • Lift the base up to remove it.
  2. Ninja Professional Blender BL660 Blender Base Replacement: 2 단계, 이미지 1/2 Ninja Professional Blender BL660 Blender Base Replacement: 2 단계, 이미지 2/2
    • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
    • Pull the power cord through the mid-section opening.
  3. Ninja Professional Blender BL660 Blender Base Replacement: 3 단계, 이미지 1/2 Ninja Professional Blender BL660 Blender Base Replacement: 3 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
  4. Ninja Professional Blender BL660 Blender Base Replacement: 4 단계, 이미지 1/2 Ninja Professional Blender BL660 Blender Base Replacement: 4 단계, 이미지 2/2
    • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
  5. Ninja Professional Blender BL660 Blender Base Replacement: 5 단계, 이미지 1/2 Ninja Professional Blender BL660 Blender Base Replacement: 5 단계, 이미지 2/2
    • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
    • Slide the cover all the way to the end of the power cord.
    • Please note that the power cord does not completely come off the cover.
결론
JOHN KIMANI
회원 가입일: 09/22/17
119 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 17
30일 전: 82
전체 시간: 2,919
