주요 콘텐츠로 건너뛰기
Nintendo 2DS Battery Replacement
필요한 것
  1. Nintendo 2DS Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. Nintendo 2DS Battery Replacement: 2 단계, 이미지 2개 중 1개 Nintendo 2DS Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Nintendo 2DS Battery Replacement: 3 단계, 이미지 3개 중 1개 Nintendo 2DS Battery Replacement: 3 단계, 이미지 3개 중 2개 Nintendo 2DS Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
결론
다른 38명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Fina Beauchamp
회원 가입일: 01/12/15
3,150 평판
안내서 6개를 작성함
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 회원
CPSU-FORTE-W15S70G1
4 회원들
안내서 35개를 작성함
댓글 5개
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - 답글
This didnt help my problem
Artemy Matveev - 답글
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - 답글
or maybe its just not working ludovic 🫡
Natalia Rabago -
Who knows, will the same battery, instead of 1300mah in original, 2000mah in 'fake' works with 2DS?
Anton Kornilov - 답글
댓글 쓰기
조회 통계:
지난 24시간: 40
지난 7일: 201
지난 30일: 909
전체 시간: 49,131
