주요 콘텐츠로 건너뛰기
Nintendo 2DS Battery Replacement
필요한 것
  1. Nintendo 2DS Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. Nintendo 2DS Battery Replacement: 2 단계, 이미지 1/2 Nintendo 2DS Battery Replacement: 2 단계, 이미지 2/2
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Nintendo 2DS Battery Replacement: 3 단계, 이미지 1/3 Nintendo 2DS Battery Replacement: 3 단계, 이미지 2/3 Nintendo 2DS Battery Replacement: 3 단계, 이미지 3/3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
결론
다른 33명이 해당 안내서를 완성하였습니다.
Fina Beauchamp
회원 가입일: 01/12/15
3,024 평판
안내서 6개 작성하였습니다
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 회원
CPSU-FORTE-W15S70G1
4 회원들
안내서 35개 작성하였습니다
댓글 4개
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - 답글
This didnt help my problem
Artemy Matveev - 답글
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - 답글
or maybe its just not working ludovic 🫡
Natalia Rabago -
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 149
30일 전: 750
전체 시간: 40,746
