주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo 2DS Rear Panel Replacement
필요한 것
  1. Nintendo 2DS Rear Panel Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Remove the ten Phillips screws attaching the rear panel.
  2. Nintendo 2DS Rear Panel Replacement: 2 단계, 이미지 1개 중 1개
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
  3. Nintendo 2DS Rear Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
    • Remove the cable from the connector
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Fina Beauchamp
회원 가입일: 01/12/15
3,255 평판
안내서 6개를 작성함
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 회원
CPSU-FORTE-W15S70G1
4 회원들
안내서 35개를 작성함
2가이드 댓글
The two top screws on the backpanel I cannot get out, I used the same screwdriver I used for every other screw.
Please help!
Evergreen - 답글
For those two screws that are on the top cap aren’t supposed to come out, if the do come out it means you’ve broken those screws. Also after unscrewing that top it should just slide up.
Leo Ochoa -
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 59
지난 30일: 260
전체 시간: 17,123
