주요 콘텐츠로 건너뛰기
Nintendo 2DS Volume Slider Replacement
필요한 것
  1. Nintendo 2DS Volume Slider Replacement, Volume Slider: 1 단계, 이미지 3개 중 1개 Nintendo 2DS Volume Slider Replacement, Volume Slider: 1 단계, 이미지 3개 중 2개 Nintendo 2DS Volume Slider Replacement, Volume Slider: 1 단계, 이미지 3개 중 3개
    • Turn the 2DS over so that the backside is facing upwards.
    • Identify the two Phillips #00 screws on the upper rear panel.
  2. Nintendo 2DS Volume Slider Replacement: 2 단계, 이미지 3개 중 1개 Nintendo 2DS Volume Slider Replacement: 2 단계, 이미지 3개 중 2개 Nintendo 2DS Volume Slider Replacement: 2 단계, 이미지 3개 중 3개
    • Loosen the two screws on the upper back panel using a Phillips #00 screwdriver.
    • The screws are captive and will not detach from the back panel or separate from the panel upon removal.
    • Use a spudger to pry the upper back panel off, starting at the indent at the center top of the panel.
    • Use a spudger and work your way around the perimeter to release the clips and then lift the panel off.
  3. Nintendo 2DS Volume Slider Replacement: 3 단계, 이미지 3개 중 1개 Nintendo 2DS Volume Slider Replacement: 3 단계, 이미지 3개 중 2개 Nintendo 2DS Volume Slider Replacement: 3 단계, 이미지 3개 중 3개
    • Use your finger or a spudger to lift and pull the battery outwards from the side closest to the outer edge.
  4. Nintendo 2DS Volume Slider Replacement: 4 단계, 이미지 3개 중 1개 Nintendo 2DS Volume Slider Replacement: 4 단계, 이미지 3개 중 2개 Nintendo 2DS Volume Slider Replacement: 4 단계, 이미지 3개 중 3개
    • Pull the stylus out from the middle of the left edge of the device.
    • Use a Phillips #00 screwdriver to remove ten 2.0 mm screws from the back panel.
    • Unlike the top rear panel, these screws come out, so be sure to keep them in a safe place.
  5. Nintendo 2DS Volume Slider Replacement: 5 단계, 이미지 3개 중 1개 Nintendo 2DS Volume Slider Replacement: 5 단계, 이미지 3개 중 2개 Nintendo 2DS Volume Slider Replacement: 5 단계, 이미지 3개 중 3개
    • Use a spudger to pry the back case off by working around the perimeter of the device, starting from the bottom of the 2DS.
    • Don't yank or pull the back case off because the camera ribbon is attached to the motherboard and back case and may rip or damage the cable or camera itself.
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the camera cable.
    • Use your spudger to gently slide the cable out of the connector.
    • Remove the back case.
  6. Nintendo 2DS Volume Slider Replacement: 6 단계, 이미지 3개 중 1개 Nintendo 2DS Volume Slider Replacement: 6 단계, 이미지 3개 중 2개 Nintendo 2DS Volume Slider Replacement: 6 단계, 이미지 3개 중 3개
    • Gently pry the side that holds the volume slider off of the 2DS.
  7. Nintendo 2DS Volume Slider Replacement: 7 단계, 이미지 3개 중 1개 Nintendo 2DS Volume Slider Replacement: 7 단계, 이미지 3개 중 2개 Nintendo 2DS Volume Slider Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the volume slider from the sidebar housing.
    • When reassembling, ensure that the volume slider is volume slider is connected to the slider on the motherboard labeled VR1.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
S. Leng
회원 가입일: 10/24/22
166 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 53
지난 30일: 227
전체 시간: 4,811
