주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo 3DS 2015 SD Card Reader Replacement
필요한 것
  1. Nintendo 3DS 2015 SD Card Reader Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 SD Card Reader Replacement: 2 단계, 이미지 2개 중 1개 Nintendo 3DS 2015 SD Card Reader Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 SD Card Reader Replacement: 3 단계, 이미지 3개 중 1개 Nintendo 3DS 2015 SD Card Reader Replacement: 3 단계, 이미지 3개 중 2개 Nintendo 3DS 2015 SD Card Reader Replacement: 3 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 SD Card Reader Replacement, SD Card Reader: 4 단계, 이미지 1개 중 1개
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 SD Card Reader Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 SD Card Reader Replacement: 6 단계, 이미지 2개 중 1개 Nintendo 3DS 2015 SD Card Reader Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tyler Starr
회원 가입일: 10/06/16
1,745 평판
안내서 7개를 작성함
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G6
4 회원들
안내서 45개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 78
지난 30일: 286
전체 시간: 8,460
