주요 콘텐츠로 건너뛰기
소개
Remove the battery in your Nintendo 3DS to replace it with a new one.
  1. Nintendo 3DS Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Battery Replacement: 2 단계, 이미지 1/2 Nintendo 3DS Battery Replacement: 2 단계, 이미지 2/2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Battery Replacement, Battery: 3 단계, 이미지 1/3 Nintendo 3DS Battery Replacement, Battery: 3 단계, 이미지 2/3 Nintendo 3DS Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
결론
다른 34명이 해당 안내서를 완성하였습니다.
David Hodson
회원 가입일: 2010년 04월 13일
147,389 평판
안내서 127개 작성하였습니다
7 Comments
Where do you buy a new battery from for your nintendo 3ds?
Midori Neko - 답글
Amazon or eBay are your friend!
Also Nintendo store sells it
Alberto -
Easy as pie. Thanks for writing this guide!
3DRepairMan - 답글
I want to buy a battery to replace the old one, do you have any stablishment in An Salvador where I can buy it?
wilfredo_montesm - 답글
https://store.nintendo.com/battery-pack-... Here it is for the 3ds and 2ds battery pack from Nintendo.
Nelson Berrios - 답글
댓글 쓰기
조회 통계:
24 시간 전: 22
7일 전: 148
30일 전: 822
전체 시간: 46,705
