주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
The 3DS charging port is soldered to the motherboard. To remove it, click here and follow this guide to remove the motherboard, and then use your soldering skills to remove and replace the charging port.
Note: steps 7-8 are for replacing the charging port piece with one from another 3DS system. You can order a new piece from amazon and just use it instead.
The guide you are currently viewing has been archived until the procedure can be updated. Following this guide may damage your device.
  1. Take out the 4 screws on the back of the system using a Phillips #00 Screwdriver.
    • Take out the 4 screws on the back of the system using a Phillips #00 Screwdriver.
  2. Remove the back cover
    • Remove the back cover
  3. Before proceeding, make sure you have removed the battery.
    • Before proceeding, make sure you have removed the battery.
  4. LCD iPhone 스크린 수리 키트
    평생 품질 보증이 적용되는 저렴한 옵션.
    키트 쇼핑하기
    수리의 질 말고 비용을 절감하세요.
    키트 쇼핑하기
  5. You will see small black screws in nine different holes. make sure you use the right screwdriver and remove them. Also remove the one silver screw that holds the game cartridge slot.
    • You will see small black screws in nine different holes. make sure you use the right screwdriver and remove them. Also remove the one silver screw that holds the game cartridge slot.
  6. After you have unscrewed all of the screws. Carefully remove the back with a spudger.
    • After you have unscrewed all of the screws. Carefully remove the back with a spudger.
  7. After you pull it open, you will see the motherboard.  Locate the charging port. It should look like this.
    • After you pull it open, you will see the motherboard. Locate the charging port. It should look like this.
  8. Using a soldering iron, desolder the old charging port.
    • Using a soldering iron, desolder the old charging port.
  9. If you got a charger port for a 3DS, you can skip this step. From another 3DS, desolder the charger port.
    • If you got a charger port for a 3DS, you can skip this step. From another 3DS, desolder the charger port.
  10. Solder the new charging port to the motherboard.
    • Solder the new charging port to the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Kaylee Morton
회원 가입일: 2016년 11월 02일
275 평판
안내서 1개 작성함
you solder with everything connected to the mobo??
jrsalinas85 - 답글
Everything but the battery. I actually took mine out of the case before doing anything. But I kept it connected to the screen. I would not do this without a very fine soldering gun.
Timothy Phillips -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 3,276
