주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Nintendo 3DS Lower Case Replacement
필요한 것
  1. Nintendo 3DS Lower Case Replacement, Back Cover: 1 단계, 이미지 1/1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Lower Case Replacement: 2 단계, 이미지 1/2 Nintendo 3DS Lower Case Replacement: 2 단계, 이미지 2/2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Lower Case Replacement, Battery: 3 단계, 이미지 1/3 Nintendo 3DS Lower Case Replacement, Battery: 3 단계, 이미지 2/3 Nintendo 3DS Lower Case Replacement, Battery: 3 단계, 이미지 3/3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Lower Case Replacement, Lower Case: 4 단계, 이미지 1/1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Nintendo 3DS Lower Case Replacement: 5 단계, 이미지 1/3 Nintendo 3DS Lower Case Replacement: 5 단계, 이미지 2/3 Nintendo 3DS Lower Case Replacement: 5 단계, 이미지 3/3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
결론
다른 7명이 해당 안내서를 완성하였습니다.
David Hodson
회원 가입일: 04/13/10
150,458 평판
안내서 127개 작성하였습니다
댓글 2개
Is this guide for the original 3ds?
Glenn Racz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 23
30일 전: 108
전체 시간: 15,666
